Hi,
I would like to have the key "SYNC" switched on when i use it (like in vdj7)
Is that possible ?
Can i do that with a command in the mapper ?
Thanks.
Georges
Is that possible ?
Thanks.
Georges
geposted Tue 20 May 14 @ 5:34 am
Not sure i understand what you mean?
Could you explain a little more.
geposted Tue 20 May 14 @ 11:48 am
Have you checked out all of the settings in options with the advanced box checked? Not sure what your looking for, but there is all kinds of sync options.
geposted Tue 20 May 14 @ 12:36 pm
