Topic: DDJ-SX VIRTUAL DJ 8 SKIN
Please don't forget to make a skin for the DDJ-SX , I'm waiting!
geposted Tue 20 May 14 @ 8:47 am
Hi Oswald
I have a DDJ-SX & I'm thinking of switching from Serato to VDJ. I used to use VDJ before I bought my SX but because it came with Serato I thought I would give it a go. Reason for my message I was just wondering how it performs with VDJ & which mapper you have used, Also do you use it for playing videos?
geposted Tue 20 May 14 @ 3:12 pm
just to chip in also .. I use SX with VDJ .. its plug and play with both VDJ 7 and VDJ 8 .. no mapper needed.
Works pretty damn good I think, although i do remap some parts to my own liking here and there
geposted Tue 20 May 14 @ 3:20 pm
I too use a SX with VDJ8 and all seams good, only thing i have a slight niggle with is when scratching on the pullback and release there is a very brief pause which there isn't in serato... Tried what everyone says to cure but still there.... Not sure why it does it.....
John
geposted Tue 20 May 14 @ 5:13 pm
Do you have forward scratch enabled?
And have you played with the rampup times?
geposted Wed 21 May 14 @ 3:08 am
Hi PatchN
Forward scratch is off and have played with rampup times, makes no difference to the very slight delay time when letting go....
John.
geposted Wed 21 May 14 @ 8:26 am
The DDJ-SX works great with Virtual DJ 7.4, have Virtual 8 installed everything works , but still testing, have a delay when loading music videos , but 8 is still in the pre-release mode, i don't use it in a gig, I use 7.4. The 7.4 DDJ-SX skin works great in 8 , but I am waiting for the new 8 skins.
geposted Wed 21 May 14 @ 8:59 am
Rnow3PRO InfinityMember since 2011
johntankard wrote :
Hi PatchN
John.
I had the same problem as you. I reset the options back to factory then set the Foward and Back Scratch to No and it works fine now.
geposted Wed 21 May 14 @ 9:16 am
