Topic: Possible problem with Automix
Drag a song over to Automix side panel and it wont display so drag it over again and two appear. Also may of mentioned before it would be good to be able to drag from Automix either to remove or drag down to bottom side list for those who have enabled this.
Just reviewed this as it does drag but remains in the list.
geposted Tue 20 May 14 @ 10:19 am
RobRoyPRO InfinitySenior staffMember since 2012
does this happens also when you choose "add to automix" or just by drag &drop...?
geposted Tue 20 May 14 @ 10:24 am
Could you reproduce this?
AFAIK this happened during the beta, but no one was able to reproduce this, because it just happens sometimes.
geposted Tue 20 May 14 @ 10:31 am
Jason KPRO InfinityMember since 2007
I noticed this happens if VDJ 8 hasn't scanned the file yet. Rather than drag the file over again, wait a sec and click a blank spot on the automix window and the file appears.
geposted Tue 20 May 14 @ 10:34 am
This happens once in a while but not all the time. Had the same scenario.
Happened yesterday also . Tried to replicate but no joy however found another issue exact duplicates won't remove can replicate that several times.
Spoke to soon. Yes you can replicate the Dragging issue.
geposted Tue 20 May 14 @ 10:36 am
