This was working in 8 before and now its not . I moved a song in my playlist to a different spot , and it's not saving now . Did the update do something
geposted Tue 20 May 14 @ 10:25 am
possibly changed setting "savePlaylist" from yes to no...?
geposted Tue 20 May 14 @ 10:28 am
My saveplaylist is set on Yes
geposted Tue 20 May 14 @ 10:30 am
Can confirm that if you move a file, it is not automatically saved...but honestly don´t know if this has being changed during the different builds....
also could not find any hint in last couple of change logs i saved
geposted Tue 20 May 14 @ 10:41 am
Okay If I ad a new song to the playlist it will save , and I can even remove it from the playlist . But If I take a song that is already in the playlist and move it to a different spot , it will not save it . I went in and opened 7.4 took my song in the playlist and moved it to the top saved it , and then closed 7.4 reopened 8 and now the song is at the top ./
geposted Tue 20 May 14 @ 10:45 am
I guess in the mean time I keep going back to 7.4 to save the playlist then until this gets fixed
geposted Tue 20 May 14 @ 1:03 pm
Did we get an answer back on this yet >
geposted Wed 21 May 14 @ 12:01 pm
