1.Bug:
1. In "Track Cleaner" the "remove zones" for the video were created and stored; with entry in the "Remixtag".
2. In the "Browser" "Batch/Load tags" is called.
3. In the "Track Cleaner" copy of "Remixtag" was overwritten by the entry of the original file.
4. After loading the copy in the deck VirtualDJ crashes and restart itself.
2.Bug
In the mix of deck 1 to deck 2 is the video is not played. It appears only a still image, which not even part of the current video. After double clicking in video preview or close and open the video window plays the video then.
The mix of deck 2 to deck 1 works correctly
example: http://di-side.de/VideoBugVD8.mp4
Konfig:
VirtualDJ v8.0.0 pc build 1782.650
Windows 8.1 Pro 64 bit
AMD Phenom II X4 945 3GHz
4GB RAM
NVIDIA GeForce GTX 660 Ti
2.Bug
Konfig:
4GB RAM
geposted Tue 20 May 14 @ 12:25 pm
