Topic: Pitch not resetting to zero
This only happens with certain songs.
When I load a track the pitch resets to zero. This works for nearly all of my tracks. But, there are some that reset to different pitches. It's always the same songs. Even if I reset the pitch on the laptop or the controller, when I load the song again it does not reset to zero.
Any suggestions
Thanks.
geposted Tue 20 May 14 @ 12:39 pm
RobRoyPRO InfinitySenior staffMember since 2012
what is your setting when you look at autoBpmMatching...? If it set to yes..try to set to no....
geposted Tue 20 May 14 @ 1:23 pm
Thanks, that's fixed it.
I love it when I have a problem and someone on here knows how to fix it.
Thanks.
geposted Tue 20 May 14 @ 1:39 pm
