I have been letting vdj8 just play on Automix at my desk while I'm working. Occasionally this happens:
http://www.djgregb.com/mp3/vdj.mp3
You can hear it at 7.6 seconds in. The song plays fine if you just put it in a player. Automix is set to Fade (remove intro/outro).
geposted Tue 20 May 14 @ 1:39 pm
so this happend during the transition from one song to another right...?
geposted Tue 20 May 14 @ 1:43 pm
Correct, it seemed to be when the first song ended and the second waveform moved "up".
geposted Tue 20 May 14 @ 1:54 pm
Very similar to the glitch when scrolling through the sampler settings.
geposted Tue 20 May 14 @ 2:06 pm
and very similar to the sound issue when using or prelistening tracks in the automix editor. sound issues start when transition starts...
geposted Tue 20 May 14 @ 2:42 pm
Anybody found a fix for this? I'm finding that automix is not mixing properly and leaving long gaps between songs sometimes, or starting a song too far into the track, despite changing the automix setting to fade (remove intro/outro) over 2 or 4 seconds
geposted Tue 20 May 14 @ 7:14 pm
I am experiencing the same issue as you all are.
joe...
geposted Wed 16 Jul 14 @ 1:36 pm
That pop also happens on the backspin effect.
geposted Wed 16 Jul 14 @ 1:45 pm
