Hi
I was just reading about some one having an issue with filter folder to show non scanned tracks. After many years of using VDJ I thought may be I should make myself familiar with Filter folders. Please help some one. Is there away I can find duplicate tracks and have a filter folder to show them. Also I do I get all my Karaoke into a filter folder. Thanx in advance.
geposted Tue 20 May 14 @ 3:33 pm
I would like to know if this is possible too.... :)
geposted Tue 20 May 14 @ 3:35 pm
It would be ideal if you could track duplicates when scanning BPM.s
geposted Tue 20 May 14 @ 3:37 pm
I concur. Duplicate file indicator with a "remove this one" from database, would be excellent.
geposted Tue 20 May 14 @ 4:00 pm
AFAIK that's not possible.
geposted Wed 21 May 14 @ 3:14 am
What's not possible? Option to delete or a filter folder that shows tracks which have duplicate names -am surprised if the latter is to possible
geposted Tue 05 Aug 14 @ 3:13 am
Well, a filter folder for duplicate filenames is kind of possible.
You could create a filter folder with filter "group by title" or "group by filename", but that results in a really long (depending on your files) list of titles in the left folder area of the browser.
But that only will find files with exactly the same title or filename.
It won't find files that are basically the same but are stored with slightly different names.
geposted Tue 05 Aug 14 @ 3:30 am
