When I plugged in my vms2 unit with vdj 8 the mapping was dreadful is there a way i can sort this out.
geposted Tue 20 May 14 @ 5:08 pm
what exactly do you mean by that ? Does the unit works as expected with the default factory mapping ?
is there somethig that doesnt work, or simply doesnt match your needs and need to change some actions (customize) ?
geposted Tue 20 May 14 @ 5:38 pm
