Just noticed that some of my song titles are black, and it's the ones that include brackets.
Is there a way around this, or should I just edit them manually.
geposted Tue 20 May 14 @ 6:16 pm
Could you post a screenshot with one of those tracks opened with Tag Editor ?
geposted Thu 22 May 14 @ 2:19 am
![](/image/71170/136465/tag not reading brackets.png)
I am having the same problems
geposted Thu 22 May 14 @ 5:04 am
Change the getRemixWhenParsingFilenames option to no.
Then start over
Then start over
geposted Thu 22 May 14 @ 5:35 am
Yes, that's fixed it. Thnaks very much.
p.s, I meant to say track info was blank, not black, in my original post, but you guys worked that out.
Thanks again.
Thanks again.
geposted Thu 22 May 14 @ 6:03 am
where is the arrow buttons showed at the page 65 of the VDJ manual ?
VDJ 8 can't import the TAGs from the new file
(only old information from V6 DataBase, grat worked in VDJ7.x)
My file (video .Mp4) its all tagged with TagScanner.
I don't want rewrite all information by hands.
TNX
TNX
geposted Fri 23 May 14 @ 9:08 am
I see what you mean.
The manual shows ten 'get info from tag' arrows, and VDJ 8 only has seven.
geposted Fri 23 May 14 @ 10:20 am
