Topic: CDG graphics, running slow/delayed on Tablets
So far most features in the new VDJ8 are great, but I am having a problem with my Tablet computers in displaying the CDG graphics for Karaoke files.
1. Is a 2 year old Samsung 500 Intel Atom 1.8GHZ processor, 2GB memory, running Windows 8.1. The graphic starts out, but hangs on 30 FPS till you hit pause, then the lyrics display some progress. Setting FPS to 7 makes them display a little better, but not usable. The sound and everything else is fine. I've even turned of the display and used the TaylaMade Video, but it doesn't update properly there either.
2. Is a Motion Computing XP tablet with an Intel Pentium 1.5GHz, with 1.49GB ram. I had to disable "Ultra Latency" for decent sound. The graphics display and track, but have flashing bars down the middle of them.
Both of these Tablets run VDJ7 fine.
geposted Tue 20 May 14 @ 11:14 pm
