Here is a particular video that is not loading fully into vdj8 that loads fine in 7. Memory limit? Im rolling with a 2gb dedicated video card, 16 gigs ram... mega Asus gaming laptop
![](/image/25337/136292/Untitled.png)
geposted Tue 20 May 14 @ 11:58 pm
Please change at OPTION -> AUTOCUE to CUE or SKIP SILENCE
If this will solve the issue i can tell you it is reported and should be fixed soon.
geposted Wed 21 May 14 @ 1:51 am
I did have it set to Autocue>Cue and switched it to Skip silence per your suggestion.... kind of fixes it... it at least is playable. However, the track loads in half the waveform area.
![](/image/91192/136528/2.png)
geposted Thu 22 May 14 @ 1:36 pm
