χρειαζομαι βοηθεια με mapping σε Χ1 mkii. vdj 8. οποιοσ μπορει ασ βοηθησει.
geposted Thu 20 Nov 14 @ 11:36 pm
Τι ακριβώς θέλεις να κάνεις;
geposted Fri 21 Nov 14 @ 1:32 am
Ξέρει κάποιος να μου πει πως κανω save τις ρυθμίσεις σε αυτό το skin (Controller by DennYo)
ούτως ώστε να κρατάει τις ρυθμίσεις και να τις εχει σε κάθε εκκίνηση.
geposted Fri 21 Nov 14 @ 12:25 pm
Denny F. wrote :
Here a little description to save your Skin Settings
Open your VDJ8 Config/Controllers and add the ONINIT command on the Keyboardmapper
write in the ONINIT command your needed Variables.
set (for set a Variable to a Value)
var_equal (for read a Value of the Variable)
& (for add more than one action on one command)
for example:
set '$variation' 1 & set '$center' 2 & set '$platter' 1
Here the List of Variables
[quote]
-Skinvariations
var_equal '$variation' 0 --- 2 & 4 Deck big
var_equal '$variation' 1 --- 2 & 4 Deck small
var_equal '$variation' 2 --- 4 Deck swap 1
var_equal '$variation' 3 --- 4 Deck swap 2
var_equal '$variation' 4 --- 4 Deck swap 1 off
var_equal '$variation' 5 --- 4 Deck swap 2 off
-Center
var_equal '$center' 0 --- Center with Custom Buttons
var_equal '$center' 1 --- Center with Mixer
var_equal '$center' 2 --- Center with Video
var_equal '$center' 3 --- Center with Scratchwave
-Wave
var_equal '$wave' 1 --- Rhythmwave
var_equal '$wave' 4 --- Rhythmwave with Beatgrid
var_equal '$wave' 3 --- Rhythmwave mirror (only Topwave Skins)
var_equal '$wave' 0 --- Horizontal Scratchwave
var_equal '$wave' 2 --- Horizontal Scratchwave with Beatgrid
-Wave size
var_equal '$wavezoom' 3 --- Wave off
var_equal '$wavezoom' 0 --- Wave size small
var_equal '$wavezoom' 1 --- Wave size middle
var_equal '$wavezoom' 2 --- Wave size large
-Wave zoom lock
var_equal '$lock' 0 --- Wave zoom on top unlock
var_equal '$lock' 1 --- Wave zoom on top lock
-prelisten
var_equal '$prelisten' 0 --- no
var_equal '$prelisten' 1 --- yes
-Plattercolor
var_equal '$platter' 0 --- dark Background
var_equal '$platter' 1 --- white Background
-Plattertime
var_equal '$time' 0 --- both times
var_equal '$time' 1 --- only left
-Cover
var_equal '$cover' 0 --- visible Cover
var_equal '$cover' 1 --- hide Cover
-Cue
var_equal '$cue' 0 --- Time to Cue
var_equal '$cue' 1 --- Name Cue
var_equal '$cue' 2 --- BPM from Cue
-Browser
var_equal '$browser' 0 --- default Browser
var_equal '$browser' 1 --- Full Browser
-Filter/Key - Attention no Global Variable - NEW SINCE V4.1.0
var_equal 'filter' 0 --- Filter
var_equal 'filter' 1 --- Key
-Cueline - NEW SINCE V4.1.0
var_equal '$cueline' 0 --- Cueline visible
var_equal '$cueline' 1 --- Cueline hide
-Cuenumbers - NEW SINCE V4.1.0
var_equal '$cuenumber' 0 --- Cuenumbers visible
var_equal '$cuenumber' 1 --- Cuenumbers hide
-Songposline - NEW SINCE V4.1.0
var_equal '$songposline' 0 --- Songposline hide
var_equal '$songposline' 1 --- Songposline visible
-MixerOrder - only 4 Deck Skins - NEW SINCE V4.1.0
var_equal '$3124' 0 --- MixerOrder 3124
var_equal '$3124' 1 --- MixerOrder 1234
for example:
[quote]
-Skinvariations
-Center
-Wave
-Wave size
-Wave zoom lock
-prelisten
-Plattercolor
-Plattertime
-Cover
-Cue
-Browser
ελπίζω να βοήθησα!!!
geposted Fri 21 Nov 14 @ 12:53 pm
απ' ότι καταλαβα βαζουμε τις επιλογες στο ONINIT του κοντρολερ .
εγω το πληκτρολογιο το εχω στο ignore. οποτε το συμπληρωσα στο ONINIT της vms εκει ειχε και άλλες εντολές βεβαια.
απλος συνέχισα με το & set klp.
Το ιδιο θα κανω και στο ONINIT της ddj sx.
ε υ χ α ρ ι σ τ ώ.
ε υ χ α ρ ι σ τ ώ.
geposted Fri 21 Nov 14 @ 3:20 pm
den xriazetai stoys kontroler arki sto ONINIT toy keyboard kai eisai ok!!! gia oloys toys controlers
edit twra ida oti exeis to pliktrologio ignore opote to afineis etsi
geposted Fri 21 Nov 14 @ 3:49 pm
Καλημερα σας! Αρχικα να πω πως το vdj 8 ειναι ενα πραγματικο στολιδι. εχω μονο μια απορια! εχοντας χρησιμοποιησει 2 διαφορετικους εξωτερικους με το 7 -και μεταφεροντας τη βαση δεδομενων στο 8- μοιραια εμφανιζονται κομματια με το ιδιο ονομα αλλα ασφαλως δεν υπαρχουν αν δεν ειναι συνδεδεμενος ο δισκος. κατανννοητο.ομως στη βαση δεδομενων παραμενουν και κομματια στα οποια εχω αλλαξει tags ή κομματια τα οποια ειχαν αναγνωστει σε φακελλους που τωρα εχω καταργησει. Υπαρχει καποιος πρακτικος τροπος να κανω μια εκκαθαριση? ενα συμμαζεμα στη βαση δεδομενων?? ευχαριστω!
geposted Mon 24 Nov 14 @ 3:45 am
Κάτω αριστερά πάνω από τα κουμπιά Α+/Α- υπάρχει ένα μικρό στρόγγυλο κουμπί. Πάτα το και επέλεξε την εκκαθάριση της βάσης δεδομένων.
geposted Mon 24 Nov 14 @ 1:13 pm
Phantom ευχαριστω πολυ!
geposted Tue 25 Nov 14 @ 1:09 am
καλησπερα στην ομαδα κι απο μενα.. εγω εχω τα yosemite 10.10.1 εχω να πω οτι τα εβαλα και δεν εκανα backup πριν, λογω οτι δεν ηξερα τι παιζει με τα μακ και λογισμικα... το δουλευω με virtual 8 και sx και ergo δουλευει αλλα λογω ραμ 4αρα ζοριζεται παρα πολυ.. οποτε αν θελετε yosemite τουλαχιστον 8ραμ... και πιστευω οτι θα εισαι ενταξει ενα κολλημα μικρο μ εκανε οταν του εκανα κλιν στην ραμ με ανοιχτο χρομε... με τα μαβερικς ειχα ανοιχτα δροπμποξ που κατεβαζε χρουμ και βιρτουαλ και δουλευε ρολοι... η γνωμη μ ειναι μην κανετε πειραματα με τα μηχανιματα της δουλειας σας και να τα βαζετε οταν ειστε σιγουροι γιατι ποτε δεν ξερετε τι γινεται... χαλασε και η αππλε... αυτοι οπως το πανε δεν μασ φτανει ουτε η 16αρα τα βαραινουν συνεχεια τα os...
τελος μια ακυρη απορια.. εναν φακελο πως γινεται να του αλλαξω θεση χωρις να χασω κιου υπαρχει τροπος? ευχαριστω!
geposted Tue 25 Nov 14 @ 4:10 am
Ta 4 MB Ram den itan arketa oute me ta Mavericks. Oi ypsiloteres apaitiseis se Ram, epeksergasti, karta grafikwn klp, den einai xaraktiristiko mono twn Apple OS. Ta idia ginontai kai se Windows. Oi logoi einai profaneis !
Mesa apo to VirtualDJ, deksi klik panw ston fakelo ->File Operations->Move to
geposted Tue 25 Nov 14 @ 6:33 am
ayto me to move to me endiaferei ki emena..ta kommatia m den mporw na ta kanw move to apo ton enan disko ston allo. gt?
geposted Wed 26 Nov 14 @ 9:09 am
exw mac .o enas diskos einai aytos tou mac o allos vrisketai sto dvd..kai oi 2 einai se morfi mac os journaled.
geposted Wed 26 Nov 14 @ 9:13 am
Mipws o diskos pou prospatheis na "grapseis" einai mono Read ? i den exeis ta swsta permissions se ena apo autous ?
Dokimase kai tin teleutaia beta build 2064
geposted Wed 26 Nov 14 @ 10:38 am
PARATHETW PHOTO ME TA INFO twn diskwn mou..ekei p leei freeagent exw ti mousiki m.
ekana repair permissions apo to disk utility ton "macintosh HD" alla ston freeagent (p vrisketai sti thesi tou DVD) dn exei tetoia epilogi.(photo no2)
geposted Fri 28 Nov 14 @ 12:14 am
Dokimase na dwseis full permission (read & write) ston xtristi "Everyone".
Episis dokimase na kaneis move ena-ena arxeio kai oxi batch move fakelous. Yparxei periptwsi to VirtualDJ na stamataei tin didikasia an vrei kapoio provlima , xwris na se eidopoiei.
geposted Fri 28 Nov 14 @ 12:37 am
kai pali tipota...
geposted Fri 28 Nov 14 @ 2:20 am
phantomdeejay με την pioneer ddj sx2 εχουμε κανενα νεο, ποτε θα ειναι σε πληρη λειτουργεια το VDJ8 για την κονσολα ?
η καποια πληροφορια ποτε?
και εαν ναι τι κανουμε?κατεβαζουμε η γινεται αυτοματα αναβαθμηση απο το vdj8?
ευχαρηστω
ευχαρηστω
geposted Sat 29 Nov 14 @ 10:48 am
Καλησπέρα παίδες,
Χρησιμοποιώ για προσωπική (ερασιτεχνική) χρήση το Virtual Dj, οπότε η free με καλύπτει πλήρως.
Στο δια ταυτα...
Είχα win 7 και είπα να δοκιμάσω τα 8, το VDj δουλεύει κομπλέ με ένα όμως θέμα:
Ενώ έχει δεχτεί την database και τα settings (όλο τον φάκελο δλδ που κράτησα πριν το format), πλέον ότι και αν κάνω δεν το αποθηκεύει.
Πχ:
Ανοίγω το πρόγραμμα και παρατηρώ πως το crossfader είναι ενεργό, πάω στο config το αλλάζω (δέχεται την ρύθμιση) αλλά μόλις κλείσει το πρόγραμμα και ξανανοίξει πάλι είναι ενεργό.
Δοκίμασα να το κάνω assing σε πλήκτρο και γίνεται πάλι το ίδιο.
Έχει κανείς καμιά ιδέα για το τι μπορεί να παίζει και πως μπορώ να το διορθώσω;
Ευχαριστώ εκ των προτέρων!
Θάνος.
Στο δια ταυτα...
Πχ:
Θάνος.
geposted Sun 30 Nov 14 @ 11:39 am
Επειδή λογικά ο σκληρός σου είναι φορμαρισμένος με NTFS δοκίμασε να ελέγξεις τα δικαιώματα των αρχείων.
Στην ανάγκη πρόσθεσε τον χρήστη "Everyone" στον φάκελο του VirtualDj και δώσε του πλήρη δικαιώματα.
geposted Mon 01 Dec 14 @ 9:26 am
