Topic: Problem DN-MC6000 with VDJ8
Hello all
I am looking to whether the user DN-MC6000 MK1 have the same problem as me.
1: INT MIX mode means more action on VDJ with the mouse on the gain function, medium, bass refine the settings for the bonton react but no action.
The auto gain function works more as soon as the controller is utlise (ok soundcard mode pc)
2: always INT MIX mode the selection (drop down menu) audio effects with EFX1 work more. the map is EFX1: effect select, activation effects is ok by EFX1 key
just to know if I'm the only one to have this malfunction?
Thank you for your answers
Ps: user VDJ France
geposted Wed 21 May 14 @ 12:45 pm
