I am loving the new sound, however too many features I use aren't ready yet with my configuration, also my MacBook Pro is running extremely hot and has now started hanging. Therefore I have reluctantly decided to use 7.4 for now.... However I do not seem able to remove 8.0 and 7.4 no longer works. For the benefit of myself, and the others in the same predicament, how would I be able to remove 8.0 and return to 7.4?
geposted Wed 21 May 14 @ 2:03 pm
Why is 7.4 not working anymore?
I'm sure you downloaded and tried to install it?
geposted Wed 21 May 14 @ 2:11 pm
I've been running v8 and v7.4.1 together on a Macbook Pro for a few weeks now. (Both apps run completely independently of each other.)
What is the issue that you are seeing with trying to run 7.4.1?
(Also, check this forum for 'tips' on getting your laptop to run cooler - Setting the SkinFPS down to a lower integer. (30 > 20... I haven't tested this myself yet, however others here have claimed this worked.)
geposted Wed 21 May 14 @ 2:30 pm
