My CPU meter goes to red and the song drags and skips for 5 seconds the goes back to normal. Also CPU meter goes to red when a song is uploading to a deck how do I fix.
Could he be other software downloaded onto laptop that making it slow down
Thank you
Thank you
geposted Wed 21 May 14 @ 6:30 pm
Could be other software if its a resource hog.
Is it Mac or PC
System Specs?
Is it Mac or PC
System Specs?
geposted Wed 21 May 14 @ 6:32 pm
It's a hp 2012 model
geposted Wed 21 May 14 @ 6:38 pm
I had no problem with the virtual Dj 7.4 but I also have mixmeister installed.
geposted Wed 21 May 14 @ 6:40 pm
I'll get the specs when I get home from work tonight
geposted Wed 21 May 14 @ 6:42 pm
About this item
Features
AMD E Series Processor
SDRAM RAM
320GB Hard Drive
15.6-Inch Screen
Genuine Windows? 7 Home Premium 64-bit
Technical Details
Brand Name:HPDisplay Size:15.6Model:2000-416dxOperating System:Genuine Windows® 7 Home Premium 64-bit, Windows 7 Home PremiumComputer Cpu Manufacturer:AMDComputer Cpu Type:AMD E SeriesHard Disk Size:320RAM Memory Technology:SDRAMDisplay Technology:High-definition widescreen LED-backlit with BrightView technologyOptical Storage Device:DVD±RW DL/CD-RWNetworking Feature:802.11b/g/n Wifi WLAN wireless, Built-in 10/100 Ethernet LAN (RJ-45 connector)Warranty:1-year limited warranty.Graphics Ram:1973Item Package Quantity:1
Product Details
Manufacturer:hpManufacturer reference:A7A78UA#ABAProduct Dimensions:14.8 inches x 9.7 inches x 1.4 inches; 5.5 pounds
Features
SDRAM RAM
320GB Hard Drive
15.6-Inch Screen
Technical Details
Product Details
geposted Thu 22 May 14 @ 1:41 am
I'd say your CPU is a little bit too weak.
(Is that your Laptop?
http://h10025.www1.hp.com/ewfrf/wc/document?cc=de&lc=de&dlc=de&docname=c03151849#N46)
Try to set your PC to high performance and, if you still use it, shut down Norton Antivirus.
geposted Thu 22 May 14 @ 4:32 am
yes that is my laptop. i got rid of the norton anti virus and ill give the high performance a a try ill let you know how that goes
geposted Thu 22 May 14 @ 7:58 am
actually, if it is your gig machine, i recommend os + vdj...and nothing else
geposted Thu 22 May 14 @ 9:12 am
It's still doing it
geposted Thu 22 May 14 @ 9:17 am
A mac
geposted Thu 22 May 14 @ 9:18 am
yes...i ment not additional progs...only which came with your operating system...
geposted Thu 22 May 14 @ 9:25 am
Could you download this tool and check what process might interrupt your sound output?
http://www.thesycon.de/deu/latency_check.shtml
geposted Thu 22 May 14 @ 10:00 am
im gonna try that now thank you ill let you know what it says
geposted Thu 22 May 14 @ 11:23 am
How long does it take to analyze
geposted Thu 22 May 14 @ 11:33 am
the DPC Latency Checker is saying:
Some device drivers on this machine behave bad and will probably
cause drop-outs in real time audio and/or video streams, to isolate
the misbehaving driver use device manager and disable/re-enable
various devices, one at at time. Try network and w-lan adapters,
Modems, internal sound devices, USB host controllers,ets.
geposted Thu 22 May 14 @ 1:16 pm
Disables Broadcom 4313gn wifi adapter
Disabled Realtek pcle fe family controller
Disabled cyber link webcam virtual driver
Disabled hp webcam 101
CPU system is steady 49% to 55% while playing music and just standby
CPU system is steady at 80% to 93% when song is loading on a deck
Then drops back down to 49% to 55% when song is loaded on a deck
geposted Thu 22 May 14 @ 2:09 pm
You should expect a peak when loading a file, that is not unusual.
for the CPU to be running at 50% idle, Suggests it may be time for an upgrade of a real sort out of what is on the machine.
geposted Thu 22 May 14 @ 2:31 pm
Yes, check your Task Manager for things like updaters that sit around doing nothing most of the time.
Also have a clear out of those little utils that sit on the right hand side of your taskbar. Some people have dozens of them!
Try this too: http://www.virtualdj.com/addons/16006/VirtualDJ_PC_Optimizer.html
geposted Thu 22 May 14 @ 2:58 pm
ola gente de virtual dj como puedo trasmitir con el controlador beloopmix y no puedo trasmitir
me pueden enseñar como aserlo por favor
geposted Thu 22 May 14 @ 4:31 pm
