Ok I have 200 buttons to set up. I need the help with the action mapping
When I type this in it works only when that page is open.. sampler_pad "Air horn"_play_stop
How do it make it so it loads no matter whats open.. this includes.
audio fx.
famous
instruments
video and scratch...
Special thanks for all the effort in this program rebuild.. I can see the end of the light at the end of the tunnel... this is freaking awesome...
audio fx.
famous
instruments
geposted Wed 21 May 14 @ 10:32 pm
sampler_bank 'audio fx' & sampler_pad 'Air Horn'
If you don't put play stop at then end, then the pad will act the same as the trigger option:
![](/image/3795/136435/2014-05-22_0612.png)
geposted Thu 22 May 14 @ 12:12 am
thanks, that isn't what I meant. I need to be able to trigger sample from all 7 banks I have going at the same time.. I want to be able to press buttons on the controller and have video with a sample on top. right now the samples have to be on that page to be able to work with the button. I want to be able to have them linked hidden and press play and work.
geposted Thu 22 May 14 @ 12:21 am
Hi!
You have to add the sample bank, just like
sample_bank 1 & sampler 15 play_stop
this would play the 15th sample of the 1st bank.
Alternatively you can type Sample_bank "audio fx" & sampler "Air Horn" play_stop
works great for me ;-)
geposted Thu 22 May 14 @ 2:33 am
