I transferred the avi files that use to be in clip bank to the sample bank and it worked. then I renamed it and the doenst work.. any ideas?
geposted Thu 22 May 14 @ 12:22 am
that's wierd...havent checked this out..and dont think I want to...until you guys figure it out lol....
geposted Thu 22 May 14 @ 12:26 am
In what way not working?
I have found that with some of them if you load the SampleEditor (CTRL+click) and make a change in their, change back and save, that this sometimes resolves any issues of not playing.
geposted Thu 22 May 14 @ 1:01 am
nope didn't work.. its a avi file . when you rename it or even loop it, it saves it and it doesn't work again... it also changes the type of file is what im guessing.
geposted Thu 22 May 14 @ 1:45 am
Can you upload one of he files to Dropbox or similar and I can test too. The report if necessary.
geposted Thu 22 May 14 @ 2:36 am
