Topic: video questions
hi
is there any way to remove the virtual dj logo from the bottom right of the outgoing video .
also I'm on a macbook pro with mavericks and I'm having trouble getting the video on the second screen without it being a mirror of the virtual dj program i just want the full screen video on the second screen
thanks in advance
mike
geposted Thu 22 May 14 @ 1:13 am
You can switch the logo off in settings:
Config -> Options -> (Select Advanced) -> videoLogo
You video to second screen. Ensure that your screen is extended (you can see the desktop wallpaper on both)
Drag the video window across to the 2nd screen and then double click on the video to enlarge to full screen.
Virtual DJ will remember the position of the window when it boots up from now on, unless you move it again.
geposted Thu 22 May 14 @ 1:15 am
RobRoyPRO InfinitySenior staffMember since 2012
settings ( advanced) videologo set to "no"
geposted Thu 22 May 14 @ 1:16 am
