Topic: VDJ on Second Computer
logged into my second computer (XP sp3) logged in and downloaded VDJ8 install:
Got the....
"VirtualDJ has encountered a problem and needs to close"
Error signature
AppName virtualdj8.exe AppVer: 8.0.0.1785 Modname: virtualdj8.exe
ModVer 8.0.0.1785 Offset 0034eac0
Exception Information
Code 0xc0000000000000000 Address: 0x000000000074eac0
Reinstall twice still the same result, runs 7.4.1 audio fine, not suitable for video although does work .... just
So where to from here???
geposted Thu 22 May 14 @ 5:20 am
Still Need help with this so following DJdads advice on another thread ...... Bump
geposted Thu 22 May 14 @ 8:42 pm
windows XP SP3 is indeed our minimum requirement, however you need to make sure that all your hardware have up-to-date drivers along with your Operating system as well.
We are not quite sure if Windows XP will be supported in a next major update, so yes i would expect some issues there. Keep in mind that even Microsoft has dumped Windows XP, so consider updating to Win7
geposted Thu 22 May 14 @ 10:10 pm
