Hi Any1
When you pull accross a track for the playlist its like a big square box, is there any way you can just have it like VDJ 7.4
Also when in the playlist you can drag the track out of the playlist, but you have to right click and remove the track. Is there a way you can remove the track without right click and remove?
Would appreciate your comments
geposted Thu 22 May 14 @ 11:47 am
Change showcoverfordragdrop in config.
geposted Thu 22 May 14 @ 11:53 am
'Delete' on a PC.
or CTRL * 'Delete' on a Mac
geposted Thu 22 May 14 @ 1:18 pm
