Topic: Multiple Video FX Mapping
Hello, if someone could help out. Two part question.
1. I'm using: "video_fx_select "Strobe" & video_fx" to trigger a single video effect but how can I map it so one effect doesn't deactivate the other?
2. How do you map a button to activate two video effects at once? For example colorize + strobe.
Thanks
geposted Thu 22 May 14 @ 5:42 pm
One Effect:
effect 'strobe' active
Two Effects, one press:
effect 'colorize' active & effect 'strobe' active
geposted Thu 22 May 14 @ 5:58 pm
djtouchdan wrote :
One Effect:
Thanks, I had tried this already but when you activate the video effects they do not obey the fx parameters.
Any ideas?
geposted Thu 22 May 14 @ 10:11 pm
Are you trying to map some specific midi controller ? Which one ?
Keep in mind that if you need to control the parameters of the effect using effect_slider x actions, you need to also select it
If you still need to use multiple effects at the same time, i would suggest to use slots instead, so ..
effect x select 'effectname' & effect x active (where x is the lost from 1 to .. )
and for the sliders you need to map one ..as
effect_slider x 1 or effect_slider x 2 (to control the first 2 parameters of the x lost)
Use .. deck master in front of each action if you wish those to apply on master
geposted Thu 22 May 14 @ 10:16 pm
