Djratedxxx919 wrote :
PLEASE MAKE THE OUTPUT OF POST FADER EFFECTS USER ASSIGNABLE?????
“Deckfxsend” and “Deckfxreturn” doesn’t work??
geposted Sun 15 Nov 20 @ 4:49 pm
Hello friends, nice to contact you,
i love the Enigma Jet sound effect, its produce a super Bass sound amplified, mixed with a short flanger cycled.
If possible to create a super Bass Booster or Loudness sound effect similar to this Enigma Jet effect, but without the flanger sound embedded on its, maybe cancel it or separate it, i need the bass or low frequencies amplifier only.
Please develop a Bass Booster with a knob adjustable.
Thank you in advanced.
geposted Thu 26 Nov 20 @ 1:29 pm
the SOUND INSURGENT wrote :
There used to be an Echo plug-in that the tail would Key up or down depending on what you set it to.
Would really love to see that updated and for the Mac side as well 🤙🏾
Anyone else remember this plugin??
geposted Sat 05 Dec 20 @ 2:20 pm
Is this not "Echo Doppler" ? TexZK updated it recently with 64bit version
https://www.virtualdj.com/plugins/index.html?addonid=80120
geposted Sat 05 Dec 20 @ 2:43 pm
Nope it’s these,
So the echo will pitch up or “key” up/down and unfortunately he only makes plugins for the PC side so I couldn’t use them even if he did update them unless he ported his code over to the Mac side.
geposted Sun 06 Dec 20 @ 12:36 am
Hello friends,
i have a query, about the Enigma Jet sound FX, its produce a super Bass sound amplified, mixed with a short Jet or flanger cycled.
Its possible to separate the Jet from the Bass Loud of Enigma Jet sound FX.
geposted Sat 12 Dec 20 @ 3:25 am
Hi all,
Is it possible to have an Echo Effect which would go up to 32 beat length (or even64 bt) instead of stopping at 8 bt.
It would be so great for using it as Dub Loop for creating more long live dubbing song with scratches!
I would only need 4, 8, 16 & 32 beats length for this effect.
Cheers
Cheers
geposted Mon 01 Feb 21 @ 3:53 pm
@zerascal1 you can squeeze more out of the FX buy halving your track bpm
set_bpm 50%
set_bpm 50%
geposted Mon 01 Feb 21 @ 4:17 pm
Yes thanks I have thought of that ;)
geposted Mon 01 Feb 21 @ 4:44 pm
1 Tape Delay Freeze effect, same or similar to Traktor Tape Delay, please??????
geposted Sat 13 Feb 21 @ 7:41 am
I love so much the new feature effect_stems,
I would love to have it available on the Sampler FX, also.
Are there effect_stems parameters, that would allow that now?
geposted Tue 02 Mar 21 @ 5:09 pm
@IIDEEJAYII no you'd have to load the sample to a deck.
geposted Tue 02 Mar 21 @ 5:38 pm
Thank you Locodog
Then it remains a Wish !
So Love VDJ .. it feels like Xmas all the time
Thank you VDJ Team
Thank you VDJ Team
geposted Tue 02 Mar 21 @ 5:58 pm
@IIDEEJAYII: in a way to somehow workaround you can use scratchbank instead of sampler
playing AUDIO scratch from another track will take the stems and effect of this track
for video samples this is another story
geposted Tue 02 Mar 21 @ 6:49 pm
locodog wrote :
Works fine
mic_talkover 20% 1000ms
this will gradually drop all decks and the sampler to 20% volume over 1000ms.
if you call the script without params (so just 'mic_talkover') it defaults to 30% over 400ms.
I might have a play and see if I can get different speeds for up & down
*edit, no you can't*
Excuse the noob question - but where does the script go for the mic_talkover action, is it as per the screenshot as i cant seem to to get it to work, many thanks
geposted Mon 08 Mar 21 @ 12:18 pm
Need to assign it to something..
At your screenshot look at the KEY field.
Select that field and click a free keyboard key you want to assign the action to
geposted Mon 08 Mar 21 @ 12:19 pm
Aha ok thank you
geposted Mon 08 Mar 21 @ 12:27 pm
Woop woop got it working thank you dood
geposted Mon 08 Mar 21 @ 12:40 pm
1. It may be possible to edit the movie so that it starts from the end to the beginning [Reverus]
2. It is possible that the feature will be in Hebrew
3. Forgive me for reacting to the previous just the great translation. Change me what I wrote to something else
geposted Thu 11 Mar 21 @ 5:52 pm
1) You can always put "Mix 'Full' Start" cue point at the end immediately followed by an action cue point with "dump" as action
The song will play reverse but video will be really crappy
No other cue point will be render, specially "Mix 'Full' Exit" so that you get a "never starting story" track goes on "playing" passed start
many things will go wrong, play/pause, scratch...
2) free to you to name it as you wish
3) It looks like no Hebrew translation exists yet, you can make a try https://www.virtualdj.com/wiki/languagediff.html
Page is minimalist and send to outdated uploaded page but translation file is uptodate
Recent uploads page : http://www.virtualdj.com/plugins/index.html?category=other&subcat=1
geposted Thu 11 Mar 21 @ 7:02 pm
