Can I set points of interest to trigger lighting scenes.
I run American dj mydmx to put together basic lighting shows and was wondering if I can set cue points in songs to trigger pre set lighting scenes.
I run vdj and mydmx on the same laptop, and they both connect via usb.
Or is there a workaround for this, or am I just wanting too much.
Thanks.
Thanks.
geposted Fri 23 May 14 @ 8:14 am
There is a plugin by SBDJ that worked on 7 and allowed you to send beat grid timing info to Freestyler.
However, I have a sneaky feeing this used a MIDI clock signal to do so - and at present there is no MIDI clock in VDJ 8.
geposted Fri 23 May 14 @ 8:35 am
Your sneaky feeling is incorrect ;)
geposted Fri 23 May 14 @ 9:06 am
So, a plugin is possible.
Do you think it's likely that one may be developed for mydmx.
geposted Fri 23 May 14 @ 9:29 am
It's not likely to be honest; I've never found mydmx to be particularly friendly when it comes to interfacing with other applications.
geposted Fri 23 May 14 @ 9:48 am
That's fair enough.
So freestyler might be an option in the future?
geposted Fri 23 May 14 @ 10:01 am
Freestyler works with v7 and I'll be releasing the v8 update shortly.
Wait a minute...are you saying there's no MIDI clock out in v8? I've been using that to send beats to Lumidesk in v7 and have aked support why it's sometimes off a bit. Their answer: Wait for v8, it will be much better.
geposted Fri 23 May 14 @ 10:34 am
The developer has said that it'll be "doing an Arnie" (it'll be back).
geposted Fri 23 May 14 @ 10:36 am
OK, thank you.
geposted Fri 23 May 14 @ 10:37 am
