Topic: PLAYLIST ORDER
Evening!
For my Mastermix Grandmaster & DMC Monsterjam discs, I created and saved a Playlist for each one using MP3Tag which is the software I use for tagging all my music and karaoke files. In V7, these Playlists always kept their order regardless of how I sorted the browser when viewing other files. I have just been having a play getting ready for a gig and noticed that V7 is not keeping the order of these Playlists as V7 did. I have tried with KeepSortOrder "Yes" and "No" and it does not work either way. These files are usually just used for background music and on Automix which is set to Type "None (Back to Back)".
Do I need to change another setting, or re-create the Playlists directly in V8 in order for them to keep their order or is this possibly a bug to be ironed out.
Many thanks.
geposted Fri 23 May 14 @ 11:45 am
As far as i know this issue has been reportet and im shure it will be fixed...;-)
Thank you! Appreciate you taking the time to reply :)
still not fixed?
History is not in Order that I played it .
