Topic: VDJ 8 video/karaoke keeps freezing
when trying to play videos / karaoke my video keeps freezing and not working....what gives???
using asus laptop with 3 gigs dedicated video
geposted Fri 23 May 14 @ 12:06 pm
You need to go into Option Videomaxmemory and change it to a lower value , I have mine set at 46 yours maybe different . Play video , then go to task manager click process , and scroll down to virtual dj see what KB its running at , best to keep it under 350,000 KB
geposted Fri 23 May 14 @ 2:06 pm
I'm having the same with my ASUS as well with a 2gb card in it, what level should the max video mem be on?
geposted Sun 17 Aug 14 @ 8:33 pm
i have a 1mb video card, and 512 seems to do the trick.. for a 2mb card, try 1024 then experiment..
geposted Mon 18 Aug 14 @ 6:14 am
hi guys im playing karaoke on version 8.2 and it freezers begining of the song how ever the music plays then the word will all of a sudden start moving again please help
geposted Sat 24 Dec 16 @ 1:41 pm
