Topic: VDJ8 Broadcasting
FjorkoPRO InfinityMember since 2006
Not working....if I follow the link given to me in the config page, I can see the little media player at the bottom of the page, but it gets greyed out after about a second...
I set it to do a direct broadcast. Turned off my Windows Firewall, and alo port forwarded UDP port 8000 on my router....still no luck..
What am I doing wrong ?
Thanks
geposted Sat 24 May 14 @ 7:09 am
thx8t88PRO InfinityMember since 2011
Same here... I feel like beta-tester right now... for the full price :o/
geposted Sat 24 May 14 @ 12:46 pm
mikadadPRO InfinityMember since 2011
I also have tried direct on 3 diff browsers(chrome, ff, and safari) on my mac and its not playing,
geposted Sat 24 May 14 @ 1:34 pm
jeremtPRO InfinityMember since 2010
You folks seems having problems with VirtualDJ 8, may be your pc or your laptop having problems, thing is that I have windows 7 on my pc and I have VirtualDJ 8 and it is working well, broadcasting well, the sound quality is so clear and I have lots of listeners. I have still got the VirtualDJ 7.4.1 on my pc. The VirtualDJ 8 is new and lots of teething problem for you folks. I have choice to have the VirtualDJ 7.4.1 or VirtualDJ 8 to broadcast.
geposted Sat 24 May 14 @ 3:09 pm
