Hello,
In the text function V.EFFECTS mode, it is impossible to cry by a newline to it appears like this:
Hello
xxxxxxxxxxx
yyyyyyyyyyyy
It appears like this: Hello xxxxxxxxxxxxxxx yyyyyyyyyyyyyy
So unreadable viewed on screens that adappte sized for display on the entire length.
With V7 ok but this is a concern V8
Yan, DJ Rewop
Hello
xxxxxxxxxxx
yyyyyyyyyyyy
Yan, DJ Rewop
geposted Sat 24 May 14 @ 8:50 am
Is this being addressed as I use this feature quite a bit & need to be able to have new lines like VDJ7
geposted Sun 25 May 14 @ 6:51 am
Not sure how you managed to add a carriage return there and have multiple lines for the Text Plugin, as ENTER doesnt seem to work, but i tried here with Notepad..created 2 lines, then copied-pate in the FX GUI, pressed APPLY and i got 2 lines on the screen.
geposted Sun 25 May 14 @ 7:14 am
In VDJ 7 you could just press the enter key to start a new line. Can this feature be brought back to VDJ 8 please?
geposted Sun 25 May 14 @ 7:54 am
It's high time this plugin got the full overhaul treatment - it hasn't seen an update in years.
geposted Sun 25 May 14 @ 9:14 am
