Forum: Old versions
Topic: VDJ 8 and Pioneer DDJ SZ issues
I have found 2 issues that i have no idea how to resolve:
1) The Led indicator in the middle of each platter does not spin when the track is playing (it does on VDJ 7.4 on the DDJ SZ)
2) When i touch the outer ring of the platter to slighty bend the pitch its WAY too sensitive and slows the song down BIG time, the same happens when you push the outer ring to fasten the song slightly .
If anyone can help it will be appreciated !
geposted Sat 24 May 14 @ 10:10 am
click settings/config tick show advanced options. then select controllers and jogsensitivity bend and change it to 0.030000
IMO that setting works well mate
also settings then audio then rampstop time and change the first 0 to 1
0.00000 to 1.00000
then stops like a turntable
I am also having the issue when a song is loaded and playing. their is no visual led rack marker in the Jog wheel. I have all the latest firmware and drivers.
Please Help
What version of VDJ 8 are you running?
vdj8
when i bought the controller it came with a card from vdj with the registration # for when I downloaded the latest version of virtual dj8
i just checked my license it is PRO INFINITY
