Topic: CUE button issues
Running a denon mc-6000 and having some cue button issues.
Sometimes the cue buttons work and then after a while they don't for example.
I load a song, set a cue point using the CUE button and then press CUE 1, then select another cue point using CUE 2 button, then when I press the main CUE button it no longer takes me to either of my saved cue points.
Not sure I have explained that very well, but hopefully you guys understand.
geposted Sat 24 May 14 @ 10:48 am
The cue point set by the CUE button in v8 is temporary and is not saved (This avoids accidentally changing cue points that you have already set and saved in a song.)
To set a permanent cue point, you need to press the appropriate HOTCUE button.
geposted Tue 27 May 14 @ 6:26 am
Thanks for the reply.
I managed to work it out in the end. I think my brain had gone into overload when I posted originally.
Thanks again.
geposted Tue 27 May 14 @ 7:35 am
