I want to take the skin VDJ8 Browser Zoon and make a daytime skin. Does VDJ8 have a way to do this? I used to be able to take the skin resizer and just select the daytime mode, but the program will not load the V8 XML files. Any ideas? Im on a windows 8.1 machine.
Thanks...
Thanks...
geposted Sat 24 May 14 @ 10:39 pm
just dl the combat skin from the dl area...there is a integratet daylight skin to switch to...
geposted Sun 25 May 14 @ 3:18 am
The Combat skin doesn't have browser zoom.
geposted Sun 25 May 14 @ 5:10 am
The combat skin also doesn't have scratch panel and is missing a bunch of other stuff the default skin has. I want to make the skin I use into daylight.. It was easy on v7 but not on v8. any ideas?
geposted Sun 25 May 14 @ 7:49 am
I guess your only option right now is to ask the skin author.
The skin resizer may get updated if you (we) are lucky.
geposted Sun 25 May 14 @ 7:53 am
Please post in the relative post
http://www.virtualdj.com/forums/90622/VirtualDJ_Skins/VirtualDJ_Skin_Resizer_Tool_(v3_0)__Mac___PC_.html
geposted Sun 25 May 14 @ 7:59 am
