Topic: Using image samples
TantrixPRO InfinityMember since 2013
I am trying to use image samples (dragging image to a sample pad) and it works...but only when using videos and not when using milkdrop. The image is only view-able when a video is loaded on one deck or another but the image disappears if there is no video loaded on a deck. Any fix for this?
geposted Sun 25 May 14 @ 1:43 am
Bump
geposted Mon 26 May 14 @ 1:47 am
I'm having an issue like this as well, but have not discovered why. Sometimes the image will appear, sometimes it will not. It's not just limited to milkdrop overpowering it as I'm experiencing the same problem with sonique visualizations and music videos as well.
geposted Fri 24 Oct 14 @ 5:12 am
