Should it be possible for this window size to be recorded in the settings ?
I guess it depends of the screen size but in my case, as I open the tag editor window, some fields are hidden and I have to straight horizontally each time.
geposted Sun 25 May 14 @ 2:37 am
![](/image/1413/136927/2014-05-25_120500.jpg)
geposted Sun 25 May 14 @ 5:40 am
Not Problem
geposted Sun 25 May 14 @ 6:16 am
1366*768
geposted Sun 25 May 14 @ 6:34 am
DJ Mila is suggesting that you resize the window by grabbing the right edge or the bottom corner.
If you make the window fill the screen, it will show the info better.
geposted Sun 25 May 14 @ 6:53 am
I can resize but the best is to record the grabbed size for next openings.
geposted Sun 25 May 14 @ 6:55 am
This is because of the language conversion.
This has been reported.
geposted Sun 25 May 14 @ 7:09 am
Thanks
geposted Sun 25 May 14 @ 7:57 am
But stills in 1900.
geposted Wed 30 Jul 14 @ 4:21 pm
Remembering a window sizing/placement is a simple coding thing that makes for a good user experience, it needs sorting out.
geposted Wed 30 Jul 14 @ 7:35 pm
This should really be for all of VDJ's window.........
geposted Wed 30 Jul 14 @ 8:28 pm
