Topic: connecting hurcules rmx to alto zmx 122 mixer
I want to connect my hercules rmx to a alto zmx 122 mixer , basically to control the mics for karaoke. I have both rca and 1/4 jack plugs .
basically so i can control the sound using my hurcules .
please can someone advise me on the best option and correct cable inputs/outputs etc . thanks in advance ,
dave
geposted Sun 25 May 14 @ 5:42 pm
Come out of the RMX as a master, outputs 1&2, with either 1/4 or RCA. Into the Mixer either 1/4 or RCA, there should be an AUX for that. Hook you mics as usual.
thank you for the reply , so the mixer has rca aux input in/out also 1/4 jack aux send /return.
sorry for the noob question but are these in/out connections the same .
thanks Dave
No, if you are going 1/4 inch, go into 5/6 or 7/8. That will give you stereo ins. I don't actually own this mixer, or the manual. I just looked at a picture of it. Your manual should give you more detail.
great got ya thanks for that . so my next question can i use the 2 track output on the mixer to connect to my amp as i only have rca connections on my amp would this work ? thank you for your help . regards dave
