Topic: Effect & Audio FX
AsTheDJPRO InfinityMember since 2008
I set the effect Length it work fine on the taps but when I use my RMX II the setting don't work like I set them,( Brakestart is one ) and Beat Grid is VERY small to see to use. & audio FX volume are to loud I set them and they some how go back to full volume.I have OSx 10.9.2 2.6ghz i7 8GB 1600MHz DDR3
geposted Sun 25 May 14 @ 6:06 pm
for the Brakestart...i dont understand whats wrong with it.
for the Beatgrid, if you mean that the docked FX GUI is too small to deal with it, then yes, we know that, we couldnt make it bigger, as it needs to fit in the FX section without losing much of the Browser, but keep in mind that the Beatgrid patterns will be probably set once (at home) and wont need to use the GUI when playing live.
for the Sampler Volume... Version 8 doesnt store the Volume, so all of them are set back to 100% when launching or even changing banks., but the GAIN of the samples (from Sample Editor) is saved, so you will have to edit that for the Samples that sound loud
geposted Sun 25 May 14 @ 6:39 pm
