Hey Team not sure which update killed camera effect but its not going now!
geposted Mon 26 May 14 @ 2:26 am
OS and Used Build...?
geposted Mon 26 May 14 @ 2:32 am
Windoze 8 build 1806.664
geposted Mon 26 May 14 @ 7:39 am
Not working here either was working previously, still works on 7.
Win 8.1 i7 8gb 7700 2gb.
geposted Mon 26 May 14 @ 9:28 am
Same here.
geposted Wed 28 May 14 @ 2:13 am
It just updated to build 1810. I click camera and VDJ8 shuts down and restarts immediately. It worked before the previous 2 updates.
geposted Wed 28 May 14 @ 6:05 am
^^^^^^^^What he said ^^^^^^^^
geposted Wed 28 May 14 @ 8:21 am
Same as above, VDJ 8 Build 1814.666, Dell Inspiron N7110, Windows 7 Ultimate SP1, 64bit, Intel Core i3-2350M @2.30GHz, 16GB RAM. I need to say that the laptop built in camera works, but soon as I switch to the Logitech C920 cam - VDJ shuts down immediatly
geposted Wed 28 May 14 @ 9:02 am
Mine works perfect , which skin you using . I am using windows 7 64bit try using the standard skin for VJ8
geposted Wed 28 May 14 @ 9:41 am
Do you honestly think I would use a non default skin with a virtually new software with new features and some bugs and a new learning curve? Maybe your behind in builds!
geposted Wed 28 May 14 @ 9:49 am
Camera is now working however image is upside down =/
geposted Wed 28 May 14 @ 10:12 am
My build right night is current 1814.666
geposted Wed 28 May 14 @ 10:13 am
I don't know - but i guess it is entirely possible that because various cameras have different drivers, this could be what is causing the issue here.
For me - i can activate it and use if for a good length of time, but then everything goes black - so you have reported, so hopefully it will be addressed.
geposted Wed 28 May 14 @ 10:15 am
Mine has been on now for approx 10 minutes so far so good
![](/image/87448/137387/cam.gif)
geposted Wed 28 May 14 @ 10:20 am
It may help, for those having issues to post which camera they are.
The Camera I have is integrated so it really does not tell me , But I am running a Alienware mx17r3 Laptop
geposted Wed 28 May 14 @ 10:30 am
Mine cam is HP Truevision HD running off a realtek driver
I am operating on HP Envy DV6 I7-2.4Ghz with 8GbRam 128GBSSD 1Tb HDD and 4Tb Ext HDD OS is 64bit Windows 8
Image is upside down and in V8 and right side up in all other apps
geposted Wed 28 May 14 @ 8:45 pm
Build 1819 and the camera still does not work. Win 7 64bit, Sony DVI-D70 PTZ camera, Ion Video 2 PC MKll. Still works in 7, and work in the first beta for 8.
geposted Thu 29 May 14 @ 1:28 am
HI, same for me !!
geposted Thu 29 May 14 @ 10:05 am
again...I dont know what everyone has or has not in their computers but mine ran allnite...this thing needs some screen resizer control in the empty Gui...
geposted Thu 29 May 14 @ 2:28 pm
