If you need a video, I can make you one but tapping the tap button to create a manual BPM does not work. The results are all over the place.
Try it or I will make a video. Please don't assume it works.
geposted Mon 26 May 14 @ 7:40 pm
I don't use this, however I tested it as well and have the same results. Some people here noted that you only need to tap it 2-4x for the BPM to be correct, however that is definitely not the case.
geposted Mon 26 May 14 @ 8:25 pm
Still does not work...
Tapping makes the BPM go crazy... Do you need a video to confirm?
geposted Wed 28 May 14 @ 6:18 pm
Same for me on PC. Tap to find the right BPM can be flaky as heck. I have stopped using it for now. I think now that batch mode BPM is fixed (Hopefully) it won't be such an issue for me and I don't have a lot of variable BPM tracks to mess with. Let's see how well v8 gets on with auto detecting BPM's from now on though.
geposted Fri 30 May 14 @ 11:29 am
