Topic: "Incompatible Pluggin" for Milkdrop Pro8
Just downloaded the Milkdrop pluggin, the version for VDJ8 and ran the exe file and it said installation was sucessfull.
The pluggin is available on the drop down list within VDJ8, however it says (incompatible) and when I try to go into it's settings or activate it I get a message to tellme so.
What have I done wrong as I've heard people are using this?
geposted Tue 27 May 14 @ 4:50 am
geposted Tue 27 May 14 @ 7:07 am
Hi SBDJ.
I already have the latest version of Direct X (well the latest available version as this is on an XP machine - I havent yet installed VDJ8 on gig computers, just one at home for testing).
geposted Wed 28 May 14 @ 4:50 am
RobRoyPRO InfinitySenior staffMember since 2012
Make shure that you have current direcX9 installed also, cause that is the version most plugins require.
So even if you have dX10 or 11, you still need dX9. Just follow the link that Scott has postet...
geposted Wed 28 May 14 @ 4:57 am
stardustkaraoke wrote :
Hi SBDJ.
just to point out, windows doesn't update dirextX 9 through windows update so everyone needs to verify their dx9 with SBDJ's link.
geposted Wed 28 May 14 @ 6:45 am
