Hi,
This thread is for my documentation as to the v8 compatibility status of my plugins.
Video Transitions:
* [PC/Mac] SBDJ Breakthrough - this is now built into v8 as Doors
* [PC] cloudbreak - this is now built into v8 as Cloud Dissolve. Inbuilt version should also be Mac compatible.
* [PC] drain - this is now built into v8 as Drain. Inbuilt version should also be Mac compatible.
* [PC] dropfade - this is now built into v8 as Drain Light. Inbuilt version should also be Mac compatible.
* [PC] jagged - this is now built into v8 as Warp. Inbuilt version should also be Mac compatible.
* [PC] lumakey - this is now built into v8 as LumaKey. Inbuilt version should also be Mac compatible.
* [PC] pixelate - this is now built into v8 as Pixelate. Inbuilt version should also be Mac compatible.
* [PC] shatter - this is now built into v8 as Shatter. Inbuilt version should also be Mac compatible.
* [PC] splodge - this is now built into v8 as Splodge. Inbuilt version should also be Mac compatible.
* [PC] jumble - this is now built into v8 as Glass. Inbuilt version should also be Mac compatible.
* [PC] rgbswap - this was never released publically and is now built into v8 as Color Swap. Inbuilt version should also be Mac compatible.
* [PC] ripples - this was never released publically and is now built into v8 as Droplets. Inbuilt version should also be Mac compatible.
* [PC] SBDJ Mask - this has now become just 'mask'
* [PC] mask - as of v2.0 this now has v8 support
Sound Effects:
* [PC/Mac] SBDJ Filter - as of v2.0 this now has v8 support
* [PC/Mac] EQ10 - this plugin is v8 only
* [PC/Mac] EQ30 - this plugin is v8 only
* [PC/Mac] SBDJ StereoChannel - this plugin is compatible with both v6 and v8 as of v1.1
* [PC/Mac] balance - this plugin is compatible with both v6 and v8 as of v1.1
Video Effects:
* [PC/Mac] ScrollText - this plugin is not v8 compatible
* [Mac] syphonserver - this plugin is not v8 compatible
* [Mac] syphonserver8 - this plugin is v8 only
* [PC] milkdrop7 - this plugin is not v8 compatible
* [PC] milkdrop8 - this plugin is v8 only
* [PC] milkdrop - this was the early version of milkdrop7/8 as one plugin before I split it out. It is now deprecated in favour of the two seperate ones.
* [Mac] camera8 - this plugin is v8 only - the inbuilt v8 camera plugin is based on this
Any other of my plugins not listed will be added at a later date.
Video Transitions:
Sound Effects:
Video Effects:
geposted Tue 27 May 14 @ 5:28 am
