Topic: Singer field
Clicking on Singer in the sidelist dosent do anything.
It used to popup an input box so i could type in a name...
Im using the Default 2 Deck > Tablet skin at 1280x1024 resolution.
geposted Tue 27 May 14 @ 9:16 am
A special icon should appear inside the Singer Column for the selected song. If you click on that icon, the pop-up window should appear.
geposted Tue 27 May 14 @ 9:37 am
yes i see the icon to the right of singer.. but clicking with mouse or touch screen does nothing..
geposted Tue 27 May 14 @ 10:25 am
Tried changing "Options>Browser>onScreenKeyboard" from On back to Auto and i can now input a name by clicking in the singer field..
why should this option interfere??
EDIT: clicking on searchbar dosent auto bring up on-screen keyboard.. (necessary for touchscreen and surface users..)
geposted Wed 28 May 14 @ 8:17 pm
If onScreenKeyboard is on auto, the keyboard will show up if you select the search with your finger, but will not come up when you select it with your mouse.
geposted Thu 29 May 14 @ 3:10 am
still not fixed in build 1820 i can click it with a mouse but i dont DJ with a mouse i use a touch screen and it wont do anything if i use my finger.
im using the 3M Microtouch, if that helps
geposted Fri 30 May 14 @ 10:56 am
