Topic: Rhythm Window Bug Fix, Previous Skins
Giving VDJ8 a spin, loving it! Wanted to use the old turntable skin Turntablist v3 but neither the wave file in the rhythm window nor the horizontal beat meter appears (Same similar problem with skin Turntablist v5.2 ) . The balance of the skin is functional. Any suggestions on a fix in the XML file or otherwise?
geposted Tue 27 May 14 @ 11:35 am
Please post your question/issue to the Skins Forum
Thank you
geposted Tue 27 May 14 @ 12:35 pm
