If you have a folder of video clips and the change time is longer than a clip, then IIRC that clip should loop until the time has expired.
geposted Sat 16 May 15 @ 4:44 pm
Hi guys... is there a video somewhere that I can look at that shows how to get a video clip to play when an MP3 file is being played in VDJ8?
I use ClipBank for this right now with VDJ7 and my ClipBank is in a loop.
Thanks in advance
Thanks in advance
geposted Fri 24 Jul 15 @ 10:04 pm
with the newest update, you can now drop a video into the video window like in V7, then it ask you to save it. This must be prepared ahead of time. You can't drop a video while the song is playing like you can in V7 (does not work like in v7).
geposted Fri 24 Jul 15 @ 10:28 pm
Could you always drop a video into the sampler?
geposted Fri 24 Jul 15 @ 10:32 pm
yes you can drag/drop it.
geposted Sat 25 Jul 15 @ 8:24 am
