Here is such a sampler does not play in Previewplayer
http://www64.zippyshare.com/v/82904746/file.html
geposted Thu 29 May 14 @ 4:52 am
How many samples do you have that are 8kHz 8 bit mono WAVs?
geposted Thu 29 May 14 @ 5:05 am
8-10 but mp3 mono makes problems too
geposted Thu 29 May 14 @ 5:26 am
Confirmed that it doesn't like mono files - but worse, after failing to play the file, it then refuses to play anything else.
[later] seems to be 8 bit unsigned that's the sticky point. 16 bit signed mono files work.
geposted Thu 29 May 14 @ 5:41 am
Thanks, problem was found and will be fixed in the next update.
geposted Wed 25 Jun 14 @ 5:30 am
