Hi Everybody,
I've mapped 2 Keys on HC 4500 for beat_juggle (1/-1).
If i press the Key with "-1" the Beat Posittion jump backward correct for 2 or 3 times and then 2 Beats forward. The Same again with the "+1" key or with Encoder Knob or Keyboard Mapping.
thanx
dj nd
thanx
dj nd
geposted Thu 29 May 14 @ 4:31 pm
Beat_juggle still doesn't work properly. This is not Beat Juggle this is Beat Shuffle. ;-) Is it a bug or by design?
thx
DJ ND
thx
DJ ND
geposted Fri 31 Oct 14 @ 8:41 am
Sorry for the delay, I must have missed your OP
I think maybe (if you're using 2 keys) you don't want beat_juggle, you want
goto +1
goto -1
beat_juggle is usually used as a single key, first press shifts the track one way the second press shifts it the other way flipflopping like that.
goto +1
goto -1
geposted Fri 31 Oct 14 @ 9:53 am
thx,
The Help tag for "Beat_Juggle" is different between English and German.
English:
<beat_juggle>Alternatively jumps one beat forward and backward
'beat_juggle 0.5' will jump 1/2 beat forward or backward</beat_juggle>
That is what you say and how it works.
but in German
<beat_juggle>Springt alternativ einen Beat vorwärts oder rückwärts.
'beat_juggle 0.5' springt 1/2 Beat vorwärts, bzw. -0.5 1/2 Beat rückwärts.</beat_juggle>
This is what i need. In German translation this Function is "Traktor" like. :-D
English:
but in German
geposted Fri 31 Oct 14 @ 1:09 pm
well, we should have used a different word... the most appropriate is "alternately" instead of "alternatively", and the beat_jungle indeed behaves like loco posted, so not a bug rather a typo in description and translation actually.
geposted Fri 31 Oct 14 @ 2:54 pm
