Songs with multiple genres (separated by a semicolon) appear now all as one genre.
Previously, a song with two genres "reggae; blues" assigned, showed up as "reggae" and "blues", now i see one entry "reggae; blues"
geposted Thu 29 May 14 @ 5:35 pm
Use a backslash instead I believe. eg; Reggae/Blues.
geposted Thu 29 May 14 @ 5:38 pm
Sorry / or \ doesn't work either.
geposted Fri 30 May 14 @ 10:25 am
Don't know what to say...works fine for me...see below.
https://www.youtube.com/watch?v=QgR7AkTr0vw&feature=youtu.be
geposted Fri 30 May 14 @ 11:49 am
I mean in the browser window it's different then it was in vdj7. Now there are semicolons visible in vdj8.
vdj7
vdj8
vdj7
vdj8
geposted Fri 30 May 14 @ 12:24 pm
OK I see your point....maybe a tech or admin can make a suggestion.
geposted Fri 30 May 14 @ 12:38 pm
Hello,
i have the same Problem.
Bobby
Bobby
geposted Sun 01 Jun 14 @ 2:36 pm
Same
geposted Tue 03 Jun 14 @ 6:05 am
+1.
This reminds me an idea. In addition to live feedback there could be a function or script that shows all the tracks on database that have all the same genres as the current playing song. GenreDiff=0? And if when is one diffrent genre then GenreDiff=1 ;)
geposted Tue 03 Jun 14 @ 9:07 am
Has this bug been fixed yet or is it in the works?
geposted Wed 04 Jun 14 @ 10:28 am
It has been reported. ;-)
geposted Wed 04 Jun 14 @ 10:37 am
Thanks Dan :)
geposted Wed 04 Jun 14 @ 10:52 am
Ach mal auf Deutsch. Das gleiche Problem!!! Da sollte doch was gehen oder?
Oh times in German. The same problem! As yet should go or what?
Steffen aus Deutschland
geposted Sat 07 Jun 14 @ 7:24 am
I liked this feature in V7 too.
Please use the same separator between the genres:
bmulders's entry:
Thanks
Stefan
bmulders's entry:
Thanks
Stefan
geposted Mon 25 Aug 14 @ 12:06 am
Please test it with the latest Beta version.
geposted Thu 11 Dec 14 @ 4:07 am
Solved!
Be careful to use the same uppercase / lowercase text, otherwise you don't see all songs belonging to a genre.
geposted Wed 17 Dec 14 @ 4:41 am
