Topic: Crackling and/or sttutering sound
mizurPRO InfinityMember since 2003
I'm noticing crackling sound in most tracks and in some even stuttering or chopping audio.
I use the DN6000 controller, any ideas?
geposted Thu 29 May 14 @ 8:17 pm
Have you tried this on another laptop yet . But it sounds like a latency issue
geposted Thu 29 May 14 @ 9:24 pm
Thanks pumpitentertainment,
I'm actually using a PC, i7, 32gb of ram, and an independent video card.
AMD Radeon 6900 with GDDR5 memory.
______________________________
By the way, anyone knows where do I activate the limiter?
geposted Thu 29 May 14 @ 10:30 pm
JoeyKJPRO InfinityMember since 2008
Default should be activated, unless you changed it....In config
geposted Thu 29 May 14 @ 10:44 pm
