Topic: Music speed
Paulm72PRO InfinityMember since 2014
Hi all, i have found a problem with some songs playing at a faster speed in vdj8 then 7, i have recorded the difference and below are links for you to hear the difference.
vdj8
http://1drv.ms/1oQGemr
vdj7
http://1drv.ms/1oQGgL1
i have only just noticed it as i have been preparing a mix for tomorrow.
geposted Fri 30 May 14 @ 5:39 am
Did you rescan the BPM? There was a bug in earlier builds of VDJ8 where some tracks had incorrect BPM's.
EDIT: I listened to both and one is pitched higher than the other meaning it is faster. My bet is it is the BPM bug from previous builds. Rescan the track and see if it makes any difference. If it does then you need to rescan your entire library again.
geposted Fri 30 May 14 @ 8:02 am
I would follow with what Craig has said, rescan your files and see if it normal after that. Or have you got VDJ8 set to pitch match? Might be you have another song loaded up and it has automatically matched the pitch to it ??
DJ Steve
geposted Fri 30 May 14 @ 9:15 am
DJ Steve
Could be he has autokey on in options perhaps. There are two modes. Keylock and autokey. I tried it once and it made some tracks sound like the chipmunks and others like Satchmo singing ;)
geposted Fri 30 May 14 @ 10:50 am
