Gang -
When I make changes to the track tags (Album, genre, etc), it does not reflect on the database. Even a reload tag and bpm scan won't do it.
This DID work as advertised in 7. Build 1819.
geposted Fri 30 May 14 @ 12:45 pm
Yes, I have also the same problem:
If the field is empty, "Batch - Load tags" will do it, but it doesn't work, if there is already a value in the field.
geposted Fri 30 May 14 @ 3:17 pm
I can confirm this.
Only updated when the field in the database is empty.
geposted Fri 30 May 14 @ 4:40 pm
I have reported this to the dev team already.
geposted Fri 30 May 14 @ 5:22 pm
Ah it's not just me then.
geposted Sat 31 May 14 @ 1:24 pm
Any good news for this issue?
geposted Mon 02 Jun 14 @ 4:43 pm
Works for me.
geposted Mon 02 Jun 14 @ 9:07 pm
Tested again with mac beta 1834.680....still not solved! :o(
I need a job like rescan, which will empty all fields and fill them with the new tags...
geposted Mon 09 Jun 14 @ 6:29 am
