Topic: All I Need to ROCK
Hey VDJ8 team,
I love The update, Good job. The only thing/s I need to really be up and running as side from the minor bug you are working on is a Virtualizer or at least Clipbank for version 8 (Mac) and Flanger Loop-out ( I live by this effect).
I love the sound quality boost.
Thank you,
geposted Fri 30 May 14 @ 3:24 pm
You mean a Visualizer...right? ;)
Milkdrop isn't for Mac, right?
No, it is currently PC only.
sonisphere wrote :
... and Flanger Loop-out ( I live by this effect)...
The old Flanged Loop-out from v7 seems to be working ok in my v8 setup (it's on a pc)
I haven't installed it again, so I guess it has just survived from the v7 installation
Mac v7 plugins aren't compatible due to the change from 32 bit to 64 bit.
I'm working on a Mac visualiser too.
Hi Guys, I need help getting Milkdrop8 To Work. I've installed & in setting set Milkdrop8 to videoaudioonlyvisualisation then opened video window & played mp3 sounds great in vdj8 but no visuals. I'm sure its something simple (like me) but cant see it, anyone help?
Hey guys, I see you've been churning away for a while now on implementing the visualizer. Any luck with the Mac plug-in?
iTunes for mac has a Visualizer, anyway to access it in virtual dj 8 ?
