Topic: Indexing slow and inaccurate.
I can't get an accurate indexing when sorting BPM and then KEY.
In Version 7 you click the top bar of BPM then top bar of KEY and the indexing is correct. Key will group all (example: A#M) songs with incrementing/decrementing BPM tracks in proper order.
Version 8 does not do that. Click on BPM top bar then KEY top bar and there is no logical sorting order. Plus the slect bar goes down to the middle of the list bar... where Version 7 has the select bar go to the top for easy grab.
Please fix this issue. I can't index music properly using the BPM and KEY columns.
geposted Sat 31 May 14 @ 11:11 am
+1 sorting would be nice to have a tick box on each column so you can 'lock' for say BPM+key.
geposted Sat 31 May 14 @ 12:11 pm
